Displays information about the Internet Group Management Protocol (IGMP) multicast access control groups. If you do not specify a VRF name or range of VRF IDs, the results show information for the Global Router. If you do specify a VRF name or range of VRF IDs, the results show information only for the VRFs you specify.
show ip igmp access
show ip igmp access vrf WORD<1-16>
show ip igmp access vrfids WORD<0-512>
None
Privileged EXEC
This command is not supported on a node configured as the DvR Leaf within a DvR domain.
The show ip igmp access command displays the following information:
Output field |
Description |
INTERFACE |
Identifies the interface where multicast access control is configured. |
GRP PREFIX |
Shows an alphanumeric string that identifies the name of the access policy. |
HOSTADDR |
Shows the IP address of the host. |
HOSTMASK |
Shows the subnet mask used to determine the host or hosts covered by this configuration. You can use the host subnet mask to restrict access to a portion of the host network. |
ACCESSMODE |
Specifies the action of the access policy. The actions are:
